View currently ongoing tasks on recording servers
Version2026r1
LanguageEnglish
If the task is not progressing as expected, you can probably find the cause in your hardware or network. A few examples are server not running, server error, too little bandwidth, or connection loss.
  1. In the Site Navigation pane, select the System Dashboard > Current Tasks.
  2. Select a recording server to see its current tasks.
