Use VictoriaLogs to view and investigate server logs
VictoriaLogs provides access to audit logs, system logs, and rule-triggered logs collected from across the XProtect system. Use the VictoriaLogs interface to search, filter, and investigate log data.
Investigate log activity
You can combine the time filter and search field to investigate specific events and activities in the system, for example:
Review recent system activity
Investigate user actions in audit logs
Trace related events using a correlation ID
Find activity related to a specific server, user, or resource
Filter by time range
Use the time filter at the top of the page to select the date and time range you want to view.
Filter by column value
Use the format:
[Column]:[Value]
For columns that contain spaces, enclose the column name in quotation marks:
"Log type":System
Search log entries
Enter a query in the search field to filter the displayed log entries. Common examples:
Task | Query |
Show all logs |
Show only system logs |
Find entries containing a specific word, e.g. device |
Perform a case-insensitive search |
Learn more
VictoriaLogs supports additional query operators and advanced filtering capabilities. For more information, see the VictoriaLogs documentation.
