Transact tab (roles)
If your system runs with XProtect Transact, specify the following permissions for the users:
Transaction sources
Name | Description |
Edit | Enables the permission to edit properties for transaction sources in the Management Client. |
Read | Enables the permission to view properties for transaction sources in the Management Client. |
Transaction definitions
Edit | Enables the permission to edit properties for transaction definitions in the Management Client. |
Read | Enables the permission to view properties for transaction definitions in the Management Client. |
