Specify which devices to include in a device group
Version2026r1
LanguageEnglish
  1. In the Overview pane, right-click the relevant device group folder.
  2. Select Edit Device Group Members.
  3. In the Select Group Members window, select one of the tabs to locate the device.
    A device can be a member of more than one device group.
  4. Select the devices you want to include, and click Add or double-click the device:
    Example of selected group members.
  5. Click OK.
  6. If you exceed the limit of 400 devices in one group, you can add device groups as subgroups under other device groups:
    Example of a subgroup.
Disabled Devices
