PTZ tab (roles)
Version2026r1
LanguageEnglish
You set up permissions for pan-tilt-zoom (PTZ) cameras on the PTZ tab. You can specify the features users/groups can use in the clients. You can select individual PTZ cameras or device groups containing PTZ cameras.
Specify the following permissions for PTZ:
Name
Description
Manual PTZ
Determines if the selected role can use PTZ functions and pause a patrolling on the selected camera.
Specify a time profile, select Always, or leave the default value that follows the default time profile defined on the Info tab for that role.
Activate PTZ presets or patrolling profiles
Determines if the selected role can move the selected camera to preset positions, start and stop patrolling profiles, and pause a patrolling.
To allow this role to use other PTZ functions on the camera, enable the Manual PTZ permission.
PTZ Priority
Determines the priority of PTZ cameras. When several users on a surveillance system want to control the same PTZ camera at the same time, conflicts may occur.
You can avoid such a situation by specifying a priority for use of the selected PTZ camera(s) by users/groups with the selected role. Specify a priority from 1 to 32,000, where 1 is the lowest priority. The default priority is 3,000. The role with the highest priority number is the one who can control the PTZ camera(s).
Manage PTZ presets or patrolling profiles
Determines the permission to add, edit and delete PTZ presets and patrolling profiles on the selected camera in both the Management Client and XProtect Smart Client.
Lock/unlock PTZ presets
Determines if the role can lock and unlock preset positions for the selected camera.
Reserve PTZ sessions
Determines the permission to set the selected camera in reserved PTZ session mode.
In a reserved PTZ session other users or patrolling sessions with higher PTZ priority are not able to take over the control.
Release PTZ sessions
Determines if the selected role can release other users' PTZ sessions from the Management Client.
You can always release your own PTZ sessions - without this permission.
