Device tab (roles)
Note
Available functionality depends on the system you are using. See: Milestone XProtect® Product Comparison Tool.
The Device tab lets you specify which features users/groups with the selected role can use for each device (for example, a camera) or device group in XProtect Smart Client.
Remember to repeat for each device. You can also select a device group, and specify role permissions for all the devices in the group in one go.
You can still select or clear such square-filled check boxes, but note that your choice in that case applies for all devices within the device group. Alternatively, select the individual devices in the device group to verify exactly which devices the relevant permission applies for.
Camera-related permissions
Specify the following permissions for camera devices:
Name | Description |
Read | The selected camera(s) will be visible in the clients. |
View live | Allows live viewing of video from the selected camera(s) in the clients. For XProtect Smart Client, it requires that the role has been granted the permission to view the clients' Live tab. This permission is granted as part of the application permissions. Specify the time profile or leave the default value. |
View restricted live | Allows live viewing of restricted video from the selected camera(s) in the clients. For XProtect Smart Client, it requires that the role has been granted the permission to view the clients' Live tab. This permission is granted as part of the application permissions. Specify the time profile or leave the default value. |
Playback > Within time profile | Allows playback of recorded video from the selected camera(s) in the clients. Specify the time profile or leave the default value. |
Playback > Limit playback to | Allows playback of recorded video from the selected camera(s) in the clients. Specify a playback limit or apply no restrictions. |
Playback restricted recordings | Allows playback of recorded restricted video from the selected camera(s) in the clients. Specify the time profile or leave the default value. |
Read sequences | Allows reading the sequence information related to, for example, the Sequence explorer in the clients. |
Smart search | Allows the user to use the Smart search function in the clients. |
Export | Allows the user to export recordings from the clients. |
Start manual recording | Allows starting manual recording of video from the selected camera(s) in the clients. |
Stop manual recording | Allows stopping manual recording of video from the selected camera(s) in the clients. |
Read bookmarks | Allows search for and read bookmark details in the clients. |
Edit bookmarks | Allows editing bookmarks in the clients. |
Create bookmarks | Allows adding bookmarks in the clients. |
Delete bookmarks | Allows deleting bookmarks in the clients. |
AUX commands | Allows the use of auxiliary commands from the clients. |
Create and extend evidence locks | Allows the client user to:
NoteRequires user permissions to all devices included in the evidence lock. |
Delete and reduce evidence locks | Allows the client user to:
Read evidence locks | Allows the client user to search for and read evidence lock details. |
Create and extend live and playback restrictions | Allows the client user to:
NoteRequires user permissions to all devices included in the restriction. |
Read live and playback restrictions | Allows the client user to:
Delete and reduce live and playback restrictions | Allows the client user to:
Microphone-related permissions
Specify the following permissions for microphone devices:
Read | The selected microphone(s) will be visible in the clients. |
Listen live | Allows listening to live audio from the selected microphones in the clients. For XProtect Smart Client, it requires that the role has been granted the permission to view the clients' Live tab. This permission is granted as part of the application permissions. Specify the time profile or leave the default value. |
Listen restricted live audio | Allows listening to live restricted video from the selected microphone(s) in the clients. For XProtect Smart Client, it requires that the role has been granted the permission to view the clients' Live tab. This permission is granted as part of the application permissions. Specify the time profile or leave the default value. |
Playback > Within time profile | Allows playback of recorded audio from the selected microphone(s) in the clients. Specify the time profile or leave the default value. |
Playback > Limit playback to | Allows playback of recorded audio from the selected microphone(s) in the clients. Specify a playback limit or apply no restrictions. |
Playback restricted recordings | Allows playback of recorded restricted audio from the selected microphone(s) in the clients. Specify the time profile or leave the default value. |
Start manual recording | Allows starting manual recording of audio from the selected microphone(s) in the clients. |
Stop manual recording | Allows stopping manual recording of audio from the selected microphone(s) in the clients. |
Speaker-related permissions
Specify the following permissions for speaker devices:
Read | The selected speaker(s) is visible in the clients. |
Listen live | Allows listening to live audio from the selected speaker(s) in the clients. For XProtect Smart Client, it requires that the role has been granted the permission to view the clients' Live tab. This permission is granted as part of the application permissions. Specify the time profile or leave the default value. |
Listen restricted live audio | Allows listening to live restricted video from the selected speaker(s) in the clients. For XProtect Smart Client, it requires that the role has been granted the permission to view the clients' Live tab. This permission is granted as part of the application permissions. Specify the time profile or leave the default value. |
Playback > Within time profile | Allows playback of recorded audio from the selected speaker(s) in the clients. Specify the time profile or leave the default value. |
Playback > Limit playback to | Allows playback of recorded audio from the selected speaker(s) in the clients. Specify a playback limit or apply no restrictions. |
Playback restricted recordings | Allows playback of recorded restricted audio from the selected speaker(s) in the clients. Specify the time profile or leave the default value. |
Start manual recording | Allows starting manual recording of audio from the selected speaker(s) in the clients. |
Stop manual recording | Allows stopping manual recording of audio from the selected speaker(s) in the clients. |
Metadata-related permissions
Specify the following permissions for metadata devices:
Read | Enables the permission to see metadata devices and retrieve data from them in the clients. |
Edit | Enables the permission to edit metadata properties. It also allows users to enable or disable metadata devices in the Management Client and via the MIP SDK. |
View Live | Enables the permission to view live metadata from cameras in the clients. For XProtect Smart Client, it requires that the role has been granted the permission to view the clients' Live tab. This permission is granted as part of the application permissions. |
View live restriction | Enables the permission to view live restricted metadata from cameras in the clients. For XProtect Smart Client, it requires that the role has been granted the permission to view the clients' Live tab. This permission is granted as part of the application permissions. |
Playback | Enables the permission to play back recorded data from metadata devices in the clients. |
Playback restricted recordings | Enables the permission to play back recorded data from restricted metadata devices in the clients. |
Read sequences | Enables the permission to use the Sequences feature while browsing recorded data from metadata devices in the clients. |
Export | Enables the permission to export recorded audio from metadata devices in the clients. |
Create and extend evidence locks | Enables the permission to create and extend the evidence locks on metadata in the clients. |
Read evidence locks | Enables the permission to view evidence locks on metadata in the clients. |
Delete and reduce evidence locks | Enables the permission to delete or reduce evidence locks on metadata in the clients. |
Start manual recording | Enables the permission to start manual recording of metadata in the clients. |
Stop manual recording | Enables the permission to stop manual recording of metadata in the clients. |
Input-related permissions
Specify the following permissions for input devices:
Read | The selected input(s) will be visible in the clients. |
Output-related permissions
Specify the following permissions for output devices:
Read | The selected output(s) will be visible in the clients. If visible, the output will be selectable on a list in the clients. |
Activate | The selected output(s) can be activated from the Management Client and the clients. Specify the time profile or leave the default value. |
