Federated site properties
Version2026r1
LanguageEnglish
This section describes the General tab and the Parent Site tab.
General tab
You can change some of the information related to the site that you are currently logged in to.
Name
Description
Name
Enter the name of the site.
Description
Enter a site description.
URLs
Use the list to add and remove URL(s) for this site and indicate if they are external or not. External addresses can be reached from outside the local network.
Version
The version number of the site's management server.
Service account
The service account under which the management server is running.
Time for last synchronization
Time and date of the last synchronization of the hierarchy.
Status for last synchronization
The status of the last synchronization of the hierarchy. It can be either Successful or Failed.
Parent Site tab
This tab shows information about the parent site of the site that you are currently logged in to. The tab is not visible if your site has no parent site.
Name
Description
Name
Shows the name of the parent site.
Description
Shows a description of the parent site (optional).
URLs
Lists URL(s) for the parent site and indicates if they are external or not. External addresses can be reached from outside the local network.
Version
Service account
