Events tab (devices)
Version2026r1
LanguageEnglish
The following devices have an Events tab:
  • Cameras
  • Microphones
  • Inputs
In addition to the system's event, some devices can be configured to trigger events. You can use these events when creating event-based rules in the system. Technically, they occur on the actual hardware/device rather than on the surveillance system.
Events tab overview for a selected device.
Tasks on the Events tab
Event tab (properties)
Name
Description
Configured events
Which events you may select and add in the Configured events list is determined entirely by the device and its configuration. For some types of devices, the list is empty.
General
The list of properties depends on the device and the event. In order for the event to work as intended, you must specify some or all of the properties identically on the device as well as on this tab.
