Enable Bing Maps or Google Maps in Management Client
Version2026r1
LanguageEnglish
You can make a key available to multiple users by entering it for a Smart Client profile in Management Client. All users who are assigned to the profile will use this key.
Steps:
  1. In Management Client, on the Site Navigation pane, click Smart Client Profiles.
  2. In the Smart Client Profiles pane, select the relevant Smart Client profile.
  3. In the Properties pane, click the Smart map tab:
    • For Bing Maps, enter your Basic Key or Enterprise Key in the Bing Maps key field
    • For Google Maps, enter your Maps Static API key in the Private key for Google Maps field
  4. To prevent XProtect Smart Client operators from using a different key, select the Locked check box.
