Disable automatic license activation
Version2026r1
LanguageEnglish
If it is not allowed to use automatic license activation in your organization, or if you have simply changed your mind, you can disable automatic license activation.
How you disable depends on whether you later plan to use automatic license activation again.
Disable but keep the password for later use:
  • From the Site Navigation pane -> Basics node -> License Information, clear Enable automatic license activation. The user name and password are still saved on the management server.
Disable and delete password:
  1. From the Site Navigation pane -> Basics node -> License Information, click Edit activation credentials.
  2. Click Delete password.
  3. Confirm that you want to delete the user name and password from the management server.
