Before you start installation
Milestone recommends that you go through the requirements described in the next sections, before you start the actual installation.
Prepare your servers and network
Decide on a SQL Server edition
How can XProtect VMS be configured to run in FIPS 140-2 compliant mode?
Before you install XProtect VMS on a FIPS enabled system
