Register Software License Code
Version2026r1
LanguageEnglish
Before you install, you must have the name and location of the software license file that you received from Milestone.
The Software License Code (SLC) is printed on your order confirmation and the software license file is named after your SLC.
Milestone recommends that you register your SLC on our website (https://online.milestonesys.com/) before installation. Your reseller may have done that for you.
