Assign user permissions
You configure user permissions for an interconnected camera as you do with other cameras, by creating a role and assigning access to functions.
On the central site, in the Site Navigation pane, expand Security and select Roles.
In the Overview pane, right-click the built-in administrator role and select Add Role (see Add and manage a role).
Name the role and configure the settings on the Device tab (see Device tab (roles)) and the Remote Recordings tab (see Remote Recordings tab (roles)).
