Add and manage a role
Version2026r1
LanguageEnglish
  1. Expand Security and right-click Roles.
  2. Select Add Role. This opens the Add Role dialog box.
  3. Enter a name and description of the new role and click OK.
  4. The new role is added to the Roles list. By default, a new role does not have any users/groups associated with it, but it does have a number of default profiles associated.
  5. To choose different Smart Client and Management Client profiles, evidence lock profiles or time profiles, click the drop-down lists.
  6. You can now assign users/groups to the role, and specify which of the system’s features they can access.
For more information, see Assign/remove users and groups to/from roles and Roles (Security node).
