Add and configure a Management Client profile
If you do not want to use the default profile, you can create a Management Client profile before you can configure it.
Right-click Management Client Profiles.
Select Add Management Client Profile.
In the Add Management Client Profile dialog box, enter a name and description of the new profile and click OK.
In the Overview pane, click the profile you created to configure it.
On the Profile tab, select or clear functionality from the Management Client profile.
