Copy a Management Client profile
Version2026r1
LanguageEnglish
If you have a Management Client profile with settings that you would like to reuse, you can copy an already existing profile and make minor adjustments to the copy instead of creating a new profile from scratch.
  1. Click Management Client Profile, right-click the profile in the Overview pane, select Copy Management Client Profile.
  2. In the dialog box that appears, give the copied profile a new unique name and description. Click OK.
  3. In the Overview pane, click the profile and go to the Info tab or Profile tab to configure the profile.
