Activate licenses online
If the management server has internet access but you prefer to manually start the activation process, this is the easiest license activation option for you.
From the Site Navigation pane -> Basics node -> License Information, select Activate License Manually and then Online.
The Activate Online dialog box opens:
If you are an existing user, enter your user name and password
If you are a new user, click the Create new user link to set up a new user account. If you have not yet registered your Software License Code (SLC), you must do so
Click OK.
If you receive an error message during online activation, follow the instructions on the screen to solve the issue or contact Milestone support.
