Forbind serverlogfiler med en ekstern overvågningsløsning
Du kan videresende serverlogfiler fra dit XProtect VMS til en ekstern overvågnings- eller logføringsløsning til centraliseret overvågning.
VMS'en bruger API Gateway til at indsamle logfiler fra systemkomponenterne, men kan videresende logfilerne til eksterne overvågningsværktøjer ved hjælp af OpenTelemetry Protocol (OTLP).
[en] For more information, see the OpenTelemetry documentation.
[en] Ports used by the system
[en] The OpenTelemetry Collector uses port 4317 by default. Additional OpenTelemetry Protocol (OTLP) configurations can use port 4318.
[en] These ports are used only for local communication on the Management Server and should be blocked by the firewall to prevent external access.
[en] If you forward log data to an external monitoring or logging solution, ensure that outbound traffic is allowed to any ports required by that solution.
