Transact tab (roles)
If your system runs with XProtect Transact, specify the following permissions for the users:
Transaction sources
Name
Description
Edit
Enables the permission to edit properties for transaction sources in the Management Client.
Read
Enables the permission to view properties for transaction sources in the Management Client.
Transaction definitions
Name
Description
Edit
Enables the permission to edit properties for transaction definitions in the Management Client.
Read
Enables the permission to view properties for transaction definitions in the Management Client.
