Server Logs node
System logs (tab)
Each row in a log represents a log entry. A log entry contains a number of information fields:
Name | Description |
Log level | Info, warning, or error. |
Local time | Timestamped in the local time of your system's server. |
Message text | The identification number for the logged incident. |
Category | The type of logged incident. |
Source type | The type of equipment on which the logged incident occurred, for example, server or device. |
Source name | The name of the equipment on which the logged incident occurred. |
Event type | The type of event represented by the logged incident. |
Audit logs (tab)
Message text | Shows a description of the logged incident. |
Permission | The information about whether the remote user action was allowed (granted) or not. |
User | The user name of the remote user causing the logged incident. |
User location | The IP address or host name of the computer from which the remote user caused the logged incident. |
Rule-triggered logs (tab)
Rule name | The name of the rule triggering the log entry. |
Service name | The name of the service on which the logged incident occurred. |
