Install a recording server through Download Manager
Last Updated: 3 minute read
If your system components are distributed on separate computers, you can install the recording servers by following the instructions below.
The recording server is already installed if you made a Single Computer installation, but you can use the same instructions to add more recording servers if you need more capacity.
You can download the component from Download Manager, see Install new XProtect components.
Start the installation
  1. Run the installer you have downloaded from Download Manager.
  2. Select the language you want to use during the installation.
  3. On the Select an installation type page, select:
    • Typical to install a recording server with default values, or
    • Custom to install a recording server with custom values.
Recording server settings
Recording servers
The Recording servers IP addresses page is shown only if you selected Custom. Specify the number of recording servers that you want to install on this computer.
Service account
Encryption
Location and language
When you have installed the recording server, you can check its state from the Recording Server Manager tray icon and configure it in Management Client.
