Edit a camera or server tile on the System monitor dashboard
If you want to monitor your cameras or servers with other monitoring parameters, you can adjust them.
In the System Monitor window, select Customize.
In the Customize dashboard window that opens, select the tile you want to change under Server tiles or Camera tiles and select Edit.
In the Edit dashboard server/camera tile window, select all cameras or servers, a camera or server group, or individual cameras or servers to change their monitoring parameters.
Under Monitoring parameters, select the monitoring parameters you want to monitor.
Select OK.
