Add a new camera or server tile on the System monitor dashboard
If you want to monitor your cameras or servers in smaller groups after their physical location, or if you want to monitor some hardware with different monitoring parameters, you can add additional tiles to the System Monitor window.
  1. In the System Monitor window, select Customize.
  2. In the Customize dashboard window that opens, select New under Server tiles or Camera tiles.
  3. In the New server tile/New camera tile window, select the cameras or servers to monitor.
  4. Under Monitoring parameters, select or clear check boxes for any parameters to add or remove from the tile.
  5. Select OK. The new server or camera tile is now added to the tiles displayed on your dashboard.
