Device tab (roles)
Last Updated: 12 minute read
Note
Available functionality depends on the system you are using. See the complete feature list, which is available on the product overview page on the Milestone website (https://www.milestonesys.com/products/software/xprotect-comparison/).
The Device tab lets you specify which features users/groups with the selected role can use for each device (for example, a camera) or device group in XProtect Smart Client.
Remember to repeat for each device. You can also select a device group, and specify role permissions for all the devices in the group in one go.
You can still select or clear such square-filled check boxes, but note that your choice in that case applies for all devices within the device group. Alternatively, select the individual devices in the device group to verify exactly which devices the relevant permission applies for.
Camera-related permissions
Specify the following permissions for camera devices:
Name
Description
Read
The selected camera(s) will be visible in the clients.
View live
Allows live viewing of video from the selected camera(s) in the clients.
For XProtect Smart Client, it requires that the role has been granted the permission to view the clients' Live tab. This permission is granted as part of the application permissions. Specify the time profile or leave the default value.
View restricted live
Allows live viewing of restricted video from the selected camera(s) in the clients.
Playback > Within time profile
Allows playback of recorded video from the selected camera(s) in the clients. Specify the time profile or leave the default value.
Playback > Limit playback to
Allows playback of recorded video from the selected camera(s) in the clients. Specify a playback limit or apply no restrictions.
Playback restricted recordings
Allows playback of recorded restricted video from the selected camera(s) in the clients. Specify the time profile or leave the default value.
Read sequences
Allows reading the sequence information related to, for example, the Sequence explorer in the clients.
Smart search
Allows the user to use the Smart search function in the clients.
Export
Allows the user to export recordings from the clients.
Start manual recording
Allows starting manual recording of video from the selected camera(s) in the clients.
Stop manual recording
Allows stopping manual recording of video from the selected camera(s) in the clients.
Read bookmarks
Allows search for and read bookmark details in the clients.
Edit bookmarks
Allows editing bookmarks in the clients.
Create bookmarks
Allows adding bookmarks in the clients.
Delete bookmarks
Allows deleting bookmarks in the clients.
AUX commands
Allows the use of auxiliary commands from the clients.
Create and extend evidence locks
Allows the client user to:
  • Add the camera to new or existing evidence locks
  • Extend the expiry time for existing evidence locks
  • Extend the protected interval for existing evidence locks
Note
Requires user permissions to all devices included in the evidence lock.
Delete and reduce evidence locks
  • Remove the camera from existing evidence locks
  • Delete existing evidence locks
  • Shorten the expiry time for existing evidence locks
  • Shorten the protected interval for existing evidence locks
Note
Read evidence locks
Allows the client user to search for and read evidence lock details.
Create and extend live and playback restrictions
  • Create a live restriction on the camera
  • Create a playback restriction on the camera recordings
  • Add a new camera to a live or playback restriction
  • Extend the restriction period of the camera recordings
Note
Requires user permissions to all devices included in the restriction.
Read live and playback restrictions
  • See a list of existing live and playback restrictions on the camera
  • Filter and search the list of live and playback restrictions on the camera
Delete and reduce live and playback restrictions
  • Remove a live restriction on the camera
  • Remove a playback restriction on the camera recordings
  • Reduce the restriction period of the camera recordings
  • Change the settings of the live or playback restriction
Note
Microphone-related permissions
Specify the following permissions for microphone devices:
Name
Description
Read
The selected microphone(s) will be visible in the clients.
Listen live
Allows listening to live audio from the selected microphones in the clients.
Listen restricted live audio
Allows listening to live restricted video from the selected microphone(s) in the clients.
Allows playback of recorded audio from the selected microphone(s) in the clients. Specify the time profile or leave the default value.
Allows playback of recorded audio from the selected microphone(s) in the clients. Specify a playback limit or apply no restrictions.
Allows playback of recorded restricted audio from the selected microphone(s) in the clients. Specify the time profile or leave the default value.
Read sequences
Export
Allows starting manual recording of audio from the selected microphone(s) in the clients.
Allows stopping manual recording of audio from the selected microphone(s) in the clients.
Read bookmarks
Edit bookmarks
Create bookmarks
Delete bookmarks
  • Add the microphone to new or existing evidence locks
Note
  • Remove the microphone from existing evidence locks
Note
Read evidence locks
  • Create a live restriction on the microphone
  • Create a playback restriction on the audio recordings
  • Add a new microphone to a live or playback restriction
  • Extend the restriction period of the audio recordings
Note
  • See a list of existing live and playback restrictions on the microphone
  • Filter and search the list of live and playback restrictions on the microphone
  • Remove a live restriction on the microphone
  • Remove a playback restriction on the audio recordings
  • Reduce the restriction period of the audio recordings
Note
Speaker-related permissions
Specify the following permissions for speaker devices:
Name
Description
Read
The selected speaker(s) is visible in the clients.
Listen live
Allows listening to live audio from the selected speaker(s) in the clients.
Allows listening to live restricted video from the selected speaker(s) in the clients.
Allows playback of recorded audio from the selected speaker(s) in the clients. Specify the time profile or leave the default value.
Allows playback of recorded audio from the selected speaker(s) in the clients. Specify a playback limit or apply no restrictions.
Allows playback of recorded restricted audio from the selected speaker(s) in the clients. Specify the time profile or leave the default value.
Read sequences
Export
Allows starting manual recording of audio from the selected speaker(s) in the clients.
Allows stopping manual recording of audio from the selected speaker(s) in the clients.
Read bookmarks
Edit bookmarks
Create bookmarks
Delete bookmarks
  • Add the speaker to new or existing evidence locks
Note
  • Remove the speaker from existing evidence locks
Note
Read evidence locks
  • Create a live restriction on the speakers
Note
  • See a list of existing live and playback restrictions on the speakers
  • Filter and search the list of live and playback restrictions on the speakers
  • Remove a live restriction on the speakers
Note
Metadata-related permissions
Specify the following permissions for metadata devices:
Name
Description
Read
Enables the permission to see metadata devices and retrieve data from them in the clients.
Edit
Enables the permission to edit metadata properties. It also allows users to enable or disable metadata devices in the Management Client and via the MIP SDK.
View Live
Enables the permission to view live metadata from cameras in the clients.
View live restriction
Enables the permission to view live restricted metadata from cameras in the clients.
Playback
Enables the permission to play back recorded data from metadata devices in the clients.
Enables the permission to play back recorded data from restricted metadata devices in the clients.
Read sequences
Enables the permission to use the Sequences feature while browsing recorded data from metadata devices in the clients.
Export
Enables the permission to export recorded audio from metadata devices in the clients.
Enables the permission to create and extend the evidence locks on metadata in the clients.
Read evidence locks
Enables the permission to view evidence locks on metadata in the clients.
Enables the permission to delete or reduce evidence locks on metadata in the clients.
Enables the permission to start manual recording of metadata in the clients.
Enables the permission to stop manual recording of metadata in the clients.
  • Create a live restriction on the metadata device
  • Create a playback restriction on the metadata device
  • Add new metadata to a live or playback restriction
  • Extend the restriction period of the metadata device
Note
  • See a list of existing live and playback restrictions on the metadata device
  • Filter and search the list of live and playback restrictions on the metadata device
  • Remove a live restriction on the metadata device
  • Remove a playback restriction on the metadata device
  • Reduce the restriction period of the metadata device
Note
Input-related permissions
Specify the following permissions for input devices:
Name
Description
Read
The selected input(s) will be visible in the clients.
Output-related permissions
Specify the following permissions for output devices:
Name
Description
Read
The selected output(s) will be visible in the clients. If visible, the output will be selectable on a list in the clients.
Activate
The selected output(s) can be activated from the Management Client and the clients. Specify the time profile or leave the default value.
