Create basic users
Last Updated: 3 minute read
Configure login settings for basic users
You can define the login settings for basic users in a JSON file, which is located here: \\Program Files\Milestone\Management Server\IIS\IDP\appsettings.json.
In that file, you can set the following parameters:
LoginSettings
"ExpireTimeInMinutes": 5
Define the length of time (in minutes) a login session will expire if the user takes no action.
LockoutSettings
"LockoutTimeSpanInMinutes": 5
Define the length of time (in minutes) a user will be locked out.
"MaxFailedAccessAttempts": 5
Define the number of attempts a user will have to log in before being locked out.
PasswordSettings
"RequireDigit": true
Define whether base digits (0 through 9) are required in the password.
"RequireLowercase": true
Define whether lowercase characters are required in the password.
"RequireNonAlphanumeric": true
Define whether special characters (~!@#$%^&*_-+=`|\(){}[]:;"'<>,.?/) are required in the password.
"RequireUppercase": true
Define whether uppercase characters are required in the password.
"RequiredLength": 8
Define the number of characters that are required in the password. There is a minimum password length of {0} characters and a maximum password length of 255 characters.
"RequiredUniqueChars": 1
Define the minimum number of unique characters that are required in a password.
For example, if you set required unique characters to 2, then passwords such as – aaaaaa, aa, a, b, bb, bbbbbbb – will be rejected.
Whereas – abab, abc, aaab, and so forth – will be accepted because there are at least two unique characters in the password.
Increasing the number of unique characters in a password increases password strength by avoiding repetitive sequences that are easily guessed.
To create a basic user on your system:
  1. Expand Security > Basic Users.
  2. In the Basic Users pane, right-click and select Create Basic User.
  3. Specify a user name and a password. Repeat the password to be sure you have specified it correctly.
    The password must meet the complexity as defined in the appsettings.json file (see Configure login settings for basic users).
  4. Specify if the basic user should change password on next login. Milestone recommends that you select the check box so that basic users can specify their own passwords when they log in for the first time.
    You should only clear the check box when you create basic users that cannot change their password. Such basic users are, for example, system users, that are used for plug-ins and server services authentication.
  5. Specify the status of the basic user to be Enabled or Locked out.
  6. Click OK to create the basic user.
