Add and edit an analytics event
Add an analytics event
  1. Expand Rules and Events, right-click Analytics Events and select Add New.
  2. In the Properties window, enter a name for the event in the Name field.
  3. Enter a description text in the Description field if needed.
  4. In the toolbar, click Save. You can test the validity of the event by clicking Test Event. You can continually correct errors indicated in the test and run the test as many times as you want and from anywhere in the process.
Edit an analytics event
  1. Click an existing analytics event to view the Properties window, where you can edit relevant fields.
  2. You can test the validity of the event by clicking Test Event. You can continually correct errors indicated in the test and run the test as many times as you want and from anywhere in the process.
Edit analytics events settings
In the toolbar, go to the Tools > Options > Analytics Events tab to edit relevant settings.
