Add a device group
  1. In the Overview pane, right-click the device type under which you want to create a device group.
  2. Select Add Device Group.
  3. In the Add Device Group dialog box, specify a name and description of the new device group:
    Example of a new device group.
    The description appears when you pause the mouse pointer over the device group in the device group list.
  4. Click OK. A folder representing the new device group appears in the list.
  5. Continue to specify which devices to include in a device group (see Specify which devices to include in a device group).
