Migrering af logserveren
Version2025r3
SprogDansk
Om migreringen
[en] The log server migration copies existing log data from the log server to VictoriaLogs or your monitoring solution. It does not affect system configuration data and is optional.
[en] If you do not migrate existing logs, historical log data remains in the log server and is removed automatically according to its retention settings.
Mens opgraderingen er i gang:
  • [en] Components that are not yet upgraded continue to send logs to the log server.
  • [en] Upgraded components send logs to Server Logs.
[en] Run the migration
  1. [en] On the log server computer, go to:
    C:\Program Files\Milestone\XProtect Management Server\Tools\LogServerMigrationTool
  2. [en] Run:
    VideoOS.LogServer.Migrate.exe
[en] A console window opens briefly and then closes automatically. No progress information or confirmation message is displayed.
[en] The absence of messages does not indicate an error. The migration tool runs without user interaction.
Efter migreringen
De eksisterende logdata fra logserveren er tilgængelige sammen med nyere logposter i serverlogfiler.
Når du ikke længere har brug for logserveren, kan du stoppe med at bruge den og tillade opbevaringsindstillinger for at fjerne resterende data.
