XProtect LPR admin manual
XProtect LPR system architecture
Version2026 R2
LanguageEnglish
The basic data flow of the system architecture in XProtect LPR.
  1. LPR cameras (a) send video to the recording server (b).
  2. The recording server sends video to the LPR servers (c) to recognize license plates by comparing them with the license plate styles in the installed country modules.
  3. LPR servers send recognitions to the event server (d) to match with the match lists.
  4. The event server sends events and alarms to XProtect Smart Client (e) when there is a match.
  5. The system administrator manages the entire LPR configuration, for example, setting up events, alarms, and lists in the Management Client (f).
LPR server
The LPR server handles LPR video recorded by your surveillance system. It analyzes the video and sends information to the event server. The event server uses the information to trigger the defined events and alarms. Milestone recommends that you install the LPR server on a computer especially allocated for this purpose.
LPR camera
The LPR camera captures video as any other camera, but some cameras are dedicated for LPR use. The better suited camera you use, the more successful recognitions you will get.
Country module
A country module tells the system how to recognize which license plates come from which countries, states, or regions—based on how the plates look and are structured. See how to enable country modules Country modules tab.
License plate styles
Match list
A match list is a set of license plate numbers, aliases, and/or vehicle properties the system can check for. When a captured license plate matches one on the match list, it can trigger actions like alerts, gate access, or law enforcement notifications. Match lists are used for cases such as security, parking control, tolling, and tracking vehicles of interest.
After you create a match list, you can set up events to recognize license plates on these lists. The events will trigger rules and alarms. See Match lists.
