XProtect LPR admin manual
Match lists tab
Version2026 R2
LanguageEnglish
On this tab, select which match list(s) you want a specific LPR camera to match license plates against. You can create as many lists as you need (see Add new match lists).
The settings for match lists in the Properties window for LPR cameras.
Name
Description
All
License plates are matched against all available and future lists.
Selected
License plates are matched against the selected lists only. Select one or more from the available lists.
After changing the settings for your LPR camera, validate your configuration (see Match lists tab) to check if the system recognizes license plates as well as expected.
