XProtect LPR admin manual
Add new match lists
Version2026 R2
LanguageEnglish
  1. In the Site Navigation pane, select Match lists, right-click and select Add New.
  2. In the window that appears, give the list a name and click OK.
    The newly created match list now appears in the Match lists window and on the Match lists tab of every LPR camera.
  3. To add columns to the match list, click Custom field and specify the columns in the window that opens (see Edit custom fields properties). You can add a maximum of five (5) columns.
  4. To update the match list, use the Add or Delete buttons (see Add match list items).
  5. Confirm your changes to save.
Note
Instead of defining the match list directly in the Management Client, you can instead import a file (see Import and export match lists).
Note
You can only edit the properties of custom fields.
