XProtect LPR admin manual
Import and export match lists
Version2026 R2
LanguageEnglish
Note
You can only import and export license plate registration numbers. Other vehicle information supported by match lists, for example aliases, cannot be imported or exported.
You can import a .csv or a .txt file with a list of license plate registration numbers that you want to use in a match list. You have the following import options:
  • Add license plate registration numbers to the existing match list.
  • Replace the existing match list.
This is useful if, for example, the match lists are managed from a central location. Then all local installations can be updated by distributing a file. Imports of a match list overwrites the current match list.
Similarly, you can export the complete list of license plate registration numbers from a match list to an external location.
To import:
  1. In the Site Navigation pane > Servers > Match lists, select the relevant match list.
  2. Select Import.
  3. In the window, specify the location of the import file and the import type. Select Next.
  4. Await the confirmation and select Close.
To export:
  2. Select Export.
  3. In the window, specify the location of the export file and select Next.
  4. Select Close.
  5. You can open and edit the exported file in, for example, Microsoft Excel.
Exports only include registration numbers and not aliases.
