XProtect LPR admin manual
Match list properties
Version2026 R2
LanguageEnglish
Name
Description
List name
Shows the name of the list. If needed, you can change the name.
Custom fields
Select to specify which license plate entry columns that you or the client user can add additional information to. See Edit match lists.
Search
Search the match list for any list item. If needed, you can use ? as a single wildcard
Add
Select to add a license plate registration number or an alias to the match list.
When you're adding license plate registration numbers:
  • Do not include any spaces
  • Always use capital letters
Examples: ABC123 (correct), ABC 123 (incorrect), abc123 (incorrect)
  • You can use wildcards in your license plate lists. Do this by defining plates with a number of ?'s and the letter(s) and/or number(s) which must appear at specific places
Examples: ?????A, A?????, ???1??, 22??33, A?B?C? and similar.
Some regional areas might have exceptions to these rules. For example, personalized plates with spaces. Plates with two sets of characters which must be recognized separately by an underscore character ( _ ). Or plates from certain regions with letters on a different background color on parts of the license plate.
Example: LP_license_plate_match_list_properties.png
Edit
Make edits to properties of custom fields.
Delete
Click to delete the selected license plate number.
Import
Click to import license plate registration numbers from any comma-separated file, for example a .txt-file or .csv-file (see Import and export match lists).
Export
Click to export the list of license plate registration numbers to a comma-separated file, for example a .txt-file or .csv-file.
Rows per page
Select how many list items to display in one page (one screen). You can choose between 50 and 1000 rows.
Events triggered by list match
Select which event(s) should be triggered by a list match. You can choose between all available types of events defined in your system.
