XProtect LPR admin manual
Camera angles
Version2026r1
LanguageEnglish
Single-line rule
Mount the camera so that you can draw a horizontal line that crosses both the left and right edge of the license plate in the captured images. See the illustrations below for correct and incorrect angles for recognition.
Single-line rule for camera angle.
Vertical angle
The recommended vertical view angle of a camera used for LPR is between 15°-30°.
Recommended vertical view angle of a camera used for LPR.
Horizontal angle
The recommended maximum horizontal view angle of a camera used for LPR is between 15°-25°.
Recommended maximum horzontal view angle of a camera used for LPR.
