XProtect Incident Manager for admins
Define and edit incident statuses
Version2026r1
LanguageEnglish
Incident statuses help the XProtect Smart Client operators track the progress of an incident investigation. The XProtect Smart Client operators can assign one status to each incident project when they update existing incident projects.
Examples of incident statuses are:
  • New
  • In progress
  • On hold
  • Closed
To define or edit an incident status in Management Client:
  1. Select Site Navigation > Incidents > Incident properties.
  2. On the Statuses tab, select:
    • Add to define a new incident status
    • Edit to update an existing incident status
    • Delete to remove an existing incident status
    Note
    You can't edit or delete incident statuses that are assigned to one or more incident projects in XProtect Smart Client. Before you edit or delete incident statuses, press F5 to refresh and include the latest changes to incident projects.
