XProtect Axis Cloud Access for operators
Typical onboarding states
Version1.1.21
LanguageEnglish
During onboarding, a device may transition through the following states:
  • PREPARING
    Initial validation and preparation of the device information.
  • FETCH_DEVICE_INFO
    Device information is retrieved from Axis Cloud.
  • REGISTERED
    The device is successfully registered in the Axis Cloud organization. Waits until Axis Cloud Connect is activated on the device.
  • CONFIGURING / INSTALLING
    Required services and cloud configuration are applied to the device.
  • FINISHED
    Onboarding is complete, and the device is ready for use.
If a problem occurs, the status may show ERROR or Failed on FINISHED
Monitoring onboarding status
From the Onboarding page:
  • Click Check device status to refresh the status of the current onboarding session.
  • Click List all devices’ status to see the onboarding state of all devices you have attempted to onboard.
From the Devices page:
  • Onboarded devices appear under Discovered Devices
  • The Status column reflects the current onboarding state (for example: Preparing, Configuring, Online)
    Both views show the same underlying progress and can be used interchangeably.
