XProtect Axis Cloud Access for operators
Removing a device
Version1.1.21
LanguageEnglish
To remove a device from the resource group and the devices list, click Remove next to the device and confirm the action.
After removal:
  • The Devices page updates within up to 2 minutes
  • The device is no longer listed
  • The number of discovered devices decreases accordingly
  • In XProtect, the device will appear offline. All existing recordings will remain, and if the device is onboarded again later, it will pick up the existing XProtect configuration.
