Removing a device
To remove a device from the resource group and the devices list, click next to the device and confirm the action.
After removal:
The Devices page updates within up to 2 minutes
The device is no longer listed
The number of discovered devices decreases accordingly
In XProtect, the device will appear offline. All existing recordings will remain, and if the device is onboarded again later, it will pick up the existing XProtect configuration.
