XProtect Axis Cloud Access for operators
Activating Axis Cloud Connect using API (advanced)
Version1.1.21
LanguageEnglish
As an alternative to manual activation, Axis Cloud Connect can be enabled remotely using the following curl command:
curl -X POST --digest -u "{CAMERA_USERNAME}:{PASSWORD}" -H "Content-Type: application/json" -d "{\"apiVersion\":\"1.0\",\"method\":\"setConfig\",\"params\":{\"state\":\"enabled\"}}" http://{CAMERA_IP}/axis-cgi/remoteservice.cgi
Replace the following values:
  • {CAMERA_USERNAME} – Device root username
  • {PASSWORD} – Device root password
  • {CAMERA_IP} – IP address of the device
Note
This method is intended for advanced users and can be used when physical access to the device is not available.
