XProtect Access for admins
XProtect Access licenses
Version2026r1
LanguageEnglish
You must purchase the following access control-related licenses to use XProtect Access:
  • One (1) base license per instance of XProtect Access. The license covers an unrestricted number of access servers.
  • One (1) access control door license for each door you want to integrate and control in XProtect Access. A door with two entry points requires only one (1) door license.
The purchase is a one-time fee, with no maintenance or annual charges after the initial purchase.
To purchase more XProtect Access base or door licenses, contact your vendor.
After you activate your XProtect Access licenses, all your purchased door licenses will be ready to be associated with your access control doors. To enable the door licenses, you must associate the included door licenses with the doors you want to use. You can only enable the same number of doors as you have door licenses for.
Examples:
  • If you want to add ten (10) doors, but only have five (5) access control door licenses, you can only add those five doors. If you want to add the remaining five doors, you must either remove some of your existing doors or purchase another five (5) door licenses.
  • You have one (1) door with two (2) access points. Even though two readers are present, you only need one (1) access control door license.
License information
In XProtect Management Client, you can see the following license information:
  • The number of available licenses and licenses in use. Available in the License information sub-node under the Basics node.
  • The doors and associated licenses. To see this license information, go to the Systems sub-node under the Access Control node. Click your access control system and select Doors and Associated Cameras.
