XProtect Access for admins
Configure access requests
Version2026r1
LanguageEnglish
You can use several types of access control events, such as Access denied and Access granted. To enable access request notifications, you must associate the type of event with the event category Access request. By default, the type of event Access denied is associated with event category Access request. Until you change it, access request notifications are sent only when someone is denied access. To change this setting, follow the steps listed below.
Requirements
You must enable notifications for the role(s) that operators belong to. On the role, click the Overall Security tab, select Access Control, and then select the Receive notifications check box.
Configuration
  1. In the Site Navigation pane, select Access Control, then Systems. Then, click the access control system you want to configure.
  2. On the Access Control Events tab, in the Access Control Event column, locate the event type that you want to edit.
  3. To disable access requests for an event type, in the Event Category column, click Configure_access_requests.png, then clear the Access request check box.
  4. To enable access requests for an additional event type, in the Event Category column, click Configure_access_requests.png and select the Access request check box.
  5. Save the changes.
