Webhook integrations
Webhooks can be set up to integrate with or without using code scripts.
No-code integrations
You can use webhooks to integrate with 3rd party no-code web applications such as Zapier, IFTTT, or Automate.io.
No-code applications help you to integrate with applications that do not themselves contain webhook integrations and help you share event data between them, with the application functioning as the facilitator of the data exchange.
For example, when an event is triggered, webhooks can be set up to:
Send an SMS message to one or more recipients
Send a message in Microsoft Teams to one or more recipients
Flash a control light in a control room
Open a support ticket
Add a row to a spreadsheet
Code integrations
You can also use webhooks to execute specific scripts on an endpoint of a web server when the event data is received.
For example, you can use webhooks to do the following when the event is triggered:
Run Python code in a Flask server
Run Node code in a Next.js server
Trigger an Amazon Lambda function
Examples of webhook integrations
The following are examples of no-code and code webhook integrations.
No-code webhook integrations
The following is an example of a webhook integration using Low-code or No-code on the receiving server.
The IF This Then That (IFTTT) web application is used as an example here, but the general guidelines can also be applied to similar web applications such as Zapier.
When integrating 3rd party No-code web applications with webhooks, the following actions generally apply:
In the 3rd party application, set up the actions to be performed based on the event that will trigger the webhook.
In the 3rd party application, copy the URL as this will be used to set up the webhook in XProtect.
In XProtectManagement Client create and set up the webhook, using the URL from the 3rd party application.
In XProtectManagement Client, create the rule that will trigger the webhook for a given event.
Tip
Remember to test your event before deploying your changes.
Example - Send an email with IFTTT when an event is triggered
This example contains several procedures that illustrate how you can use the IF This Then That (IFTTT) web application to send an email message to a Gmail account when an event is triggered in your XProtect system.
1. Connect a webhook in IFTTT
First, create the IFTTT Applet that will send the Gmail message for the event and save the resulting URL.
Note
You must create an IFTTT user in order to utilize the features of the IFTTT website.
Go to the IFTTT website and log in with your IFTTT credentials.
Create a new Applet: https://ifttt.com/create
Set up the If This part:
Click If This
Search for Webhooks
Click the blue Webhooks tile
Click Receive a web request with a JSON payload
Click Connect
Write xprotect_test in Event Name
Click Create trigger
Set up the Then That part:
Click Then That
Search Gmail
Click the blue Gmail tile
Click Send yourself an email
Click Connect
Click Create action
Click Continue
Click Finish
Go to https://ifttt.com/maker_webhooks
Click Documentation
Identify your URL. The URL should be something similar to: https://maker.ifttt.com/trigger/{event}/json/with/key/lPY4YYsvGSfTSJBM54MrDDSOGWTmk6z9VSD113hxoDY
Replace {event} with xprotect_test. The URL should end up similar to: https://maker.ifttt.com/trigger/xprotect_test/json/with/key/lPY4YYsvGSfTSJBM54MrDDSOGWTmk6z9VSD113hxoDY
Copy and save this address. The address should not be shared with unauthorized users.
2. Create a webhook in XProtect
After you have set up the applet in IFTTT, you must create the webhook in XProtect, using the URL you created in steps 9-11 above when setting up the IFTTT applet.
In Management Client > Rules and Events > Webhooks, right-click Webhooks and select Add New…
In Webhook Information:
Name field: Enter “IFTTT Gmail”
Address field: Set the address to the one from step 11 of the previous section. It should be something similar to: https://maker.ifttt.com/trigger/xprotect_test/json/with/key/lPY4YYsvGSfTSJBM54MrDDSOGWTmk6z9VSD113hxoDY
Click Save in the toolbar to save the new webhook.
3. Trigger the webhook with a rule in XProtect
After you have created and set up a webhook, you must create and set up an event to trigger the webhook.
In Management Client > Rules and Events > Rules, right-click Rules and select Add Rule… to start the Manage Rule wizard at Step 1: Type of rule.
In Step 1: Type of rule > Name field, enter
Send Gmailand add an optional description of the rule in the Description field.In the Select the rule type you want you create pane, select Perform an action on <event>
In the Edit the rule description pane, click event and in Events > External Events > User-defined Events, select Event High.
Click OK to create the event.
Click Next to go to Step 2: Conditions.
In Step 2: Conditions, apply any conditions relevant to the event you are creating.
Click Next to go to Step 3: Actions.
In Step 3: Actions, scroll down and select Send event info to <Webhook>.
Click address on the Edit the rule description pane
Add the IFTTT Gmail webhook and click OK.
Click Next to go to Step 4: Stop criteria.
In Step 4: Stop criteria, click Finish to create the rule.
4. Test the webhook from XProtect (Optional)
You should test the event to verify that the event triggers and sends the email as it should before utilizing the event and webhook in daily operations.
Open Management Client > Rules and Events and click User-defined Events.
Select Event High and click Test Event to test the event.
Open the inbox of the Gmail account you specified in the IFTTT web application above to verify you have received the correct email with the event you triggered.
5. Changing the email content (Optional)
You can change the content of the existing email message sent through the IFTTT web application.
Go to My Applets - IFTTT
Click the If Maker Event ‘xprotect_test’, then ...Applet
Click Settings
Click Then
Edit the text of the email subject or email body, for example rename the subject to
Event High from XProtectClick Update action and then click Update.
Code webhook integrations
The following are examples of webhook integrations using code on the receiving server.
When integrating 3rd party server with webhooks, the following actions generally apply:
Start a web server with en endpoint listening for webhooks.
Locate and copy the address to the receiving server as this will be used to set up the webhook in XProtect.
In XProtectManagement Client, create and set up the webhook, using the address of the receiving server.
Tip
Example: Receiving events from XProtect in Node.js (with Express)
This example illustrates how to receive events from XProtect in a Node.js Express server using webhooks.
1. Create and start a Node.js Express server
First you must create and start a web server that listens for incoming events.
Download and install Node.js from https://nodejs.org.
Create a folder anywhere in your file system and name the folder webhooks.
Open a terminal and navigate to the webhooks folder you just created.
Run npm init and use the default values.
Run npm install express.
Inside the webhooks folder, create a file and name the file index.js.
Open the index.js file in a text editor and paste the sample code below into the index.js file.
const express = require('express'); const crypto = require('crypto'); // change SECRET_TOKEN for your own token // never hard code the token in the code // we do it only for demonstration purposes // instead, store it as an environment variable const SECRET_TOKEN = "32212c72863c01a931609c5ebfe1abc5"; const isSignatureValid = (body, headerSignature, secretToken) => { const digest = crypto.createHmac("sha256", secretToken).update(body).digest(); const expectedSignature = `sha256=${digest.toString('base64').toString('utf-8')}`; if (expectedSignature.length !== headerSignature?.length) return false; return crypto.timingSafeEqual(Buffer.from(headerSignature), Buffer.from(expectedSignature)); } const app = express(); app.use(express.json()); app.post('/webhooks', (req, res) => { if (!isSignatureValid( JSON.stringify(req.body), req.headers['x-hub-signature-256'], SECRET_TOKEN)){ console.log('Received event with invalid signature'); return res.status(403).end(); } console.log('Received event from XProtect through Webhook:'); console.log(req.body); res.send(''); }) app.listen(5000, () => { console.log(`Server started...`); })In the terminal, run
node -p "require('crypto').randomBytes(64).toString('hex');"to generate your own secret token.Copy the token string and paste it in line 8 of index.js replacing the example token.
Save the index.js file
Use the terminal to run
node index.js. The log message Server started should be displayed.
After you have started the server, you must create the webhook in XProtect.
Name field: Enter
Node integrationToken (optional) field: Enter the token string you copied into the index.js file.
Address field: Set the address of the receiving server.
If you created the Node.js server on the same machine as the Event Server, enter
http://127.0.0.1:5000/webhooksIf you created the Node.js server on a server with a public IP address, enter
https://<IP>:5000/webhookswhere<IP>is the IP address of the server with a public address.For Node.js servers on machines without public addresses, see the section below.
You can use http:// instead of https://, but using http:// through non-secure networks may expose event data in plain text. Using the more secure https:// is strongly recommended.
For Node.js servers without public addresses
If you created the Node.js server on a machine on a different network and without a public IP address, for example on a development or testing machine, you can use NGrok for testing purposes.
Install https://ngrok.com/ in the same machine you installed the Node.js server on.
On your machine, locate and run ngrok http 5000
Copy the generated public address and insert the address in the Address field above. The NGrok public address should be something similar to: https://0c60-12-212-221-50.eu.ngrok.io
Send Event High to Nodeand add an optional description of the rule in the Description field.In the Select the rule type you want you create pane, select Perform an action on <event>
Click webhook on the Edit the rule description pane
Add the Node integration webhook and click OK.
You should test the event to verify that the event triggers and is recieved in the Express server before utilizing the event and webhook in daily operations.
Open the console that is running the server. The Received event from XProtect through Webhook log message should be displayed.
5. Troubleshooting (Optional)
If you don’t receive the events in your web server, open the MIP Logs from the Event Server tray icon to troubleshoot any potential errors.
Note
The log of the error can take up to 90 seconds to appear because of the retry policy.
Example: Receiving events from XProtect in Python (with Flask)
This example illustrates how to receive events from XProtect on a Python Flask server using webhooks.
1. Create and start a Python Flask server
Create a virtual environment inside the folder by using the command
python -m venv venvActivate the virtual environment by using the command
\venv\Scripts\activateInstall the Flask server by using the command
pip install flaskInside the webhooks folder, create a file and name the file main.py.
Open the main.py file in a text editor and paste the sample code below into the main.py file.
from flask import Flask, request import hashlib import hmac import base64 # change SECRET_TOKEN for your own token # never hard code the token in the code # we do it only for demonstration purposes # instead, store it as an environment variable SECRET_TOKEN = bytes("383b9d27c4a892626881d73b0f70c5b62b213ab89d33c8788ac85bd750dbdf59", 'utf-8') def is_signature_valid(body: bytes, header_signature: str, secret_token: bytes) -> bool: digest: bytes = hmac.HMAC(key=secret_token, msg=body, digestmod=hashlib.sha256).digest() expected_signature: str = f"sha256={base64.b64encode(digest).decode('utf-8')}" return hmac.compare_digest(header_signature, expected_signature) app = Flask(__name__) @app.route('/webhooks', methods=['POST']) def webhooks(): body = request.data header_signature = request.headers.get('X-Hub-Signature-256', '') if not is_signature_valid(body, header_signature, SECRET_TOKEN): print('Received event with invalid signature') return '', 403 print("Received event from XProtect through Webhook:") print(request.json) return '', 200 app.run(host='127.0.0.1', port=5000)In the Python interpreter, run the
import secrets; print(secrets.token_hex(32))command to generate your own secret token string.Copy and paste the token string in line 10 of the main.py script file, replacing the dummy token string of the sample code.
Save your changes to the main.py script file.
Use the terminal to run the python main.py command. The * Serving Flask app 'main' log message should be displayed.
Name field: Enter
Python integrationToken (optional) field: Enter the token string you copied into the main.py file.
If you installed Python on the same machine where the Event Server, enter
http://127.0.0.1:5000/webhooksIf you installed Python on a server with a public IP address, enter
https://<IP>:5000/webhookswhere<IP>is the IP address of the server with a public address.For Python installed on machines without public addresses, see the section below.
You can use http:// instead of https://, but using http:// through non-secure networks may expose event data in plain text. Using the more secure https:// is strongly recommended..
For Python on machines without public addresses
If you installed Python on a machine on a different network and without a public IP address, for example on a development or testing machine, you can use NGrok for testing purposes.
Install https://ngrok.com/ on the same machine you installed Python on.
Send Event High to Pythonand add an optional description of the rule in the Description field.In the Select the rule type you want you create pane, select Perform an action on <event>
Add the Python integration webhook and click OK.
You should test the event to verify that the event triggers and is received in the Flask server before utilizing the event and webhook in daily operations.
Note
