OpenTelemetry Audit Logs
OpenTelemetry Protocol
OpenTelemetry Protocol (OTLP) is specified as the default transport protocol within the OpenTelemetry frame-work. It is used to transmit telemetry data between components and backend systems, ensuring consistent data format and behavior across different sources and destinations. This facilitates integration with observability tools without the need for custom adapters or format conversions.
