Log Server support
Log Server compatibility: In the new architecture, the existing Log Server is no longer a required component and does not interact with the OpenTelemetry pipeline. However, it remains fully supported and can operate in par-allel. Services are already equipped to emit logs through the OpenTelemetry protocol and will begin doing so once a valid configuration has been provided. This allows the system to transition gradually, enabling continued use of the Log Server while adopting the new model at a controlled pace.
