ONVIF driver overview
Video settings
Last Updated: 6 minute read
The general video settings are video settings per device channel. If a device supports more than one channel, those settings can be configured differently for each channel. In the Management Client they are placed in the Settings tab.
For devices with one channel, there is only one general settings section. If the configuration is changed, it will be applied on all video streams (profiles) for that channel. For multi-channel devices, there are video general settings for each channel separately.
Setting name
Possible values
Value taken from device
Default value
Brightness
[0,100]
50
Contrast
[0,100]
50
Saturation
[0,100]
50
Sharpness
[0,100]
50
White Balance Mode
Auto
Manual
Auto
White Balance Cb Gain
[0,100]
50
White Balance Cr Gain
[0,100]
50
OSD Date And Time
Disabled
Up Left
Up Right
Down Left
Down Right
Custom
Disabled
OSD Date And Time X
[0, 100]
0
OSD Date And Time Y
[0, 100]
0
PTZ Zoom Step
[0, 100]
10
PTZ send zoom parameter
Always
When Changed
Always
If the device does not support white balance, the White Balance settings will not be displayed. If White Balance Mode is Manual, White Balance Cb Gain and White Balance Cr Gain are available. If White Balance Mode is AUTO, White Balance Cb Gain and White Balance Cr Gain values do not have an impact on the setup.
If the device does not support OSD that displays the date and time, the settings OSD Date and Time, OSD Date and Time X and OSD Date and Time Y will not be displayed. Support for Date and Time OSD was added in Device Pack 10.6. Some of the positions for OSD Date and Time might not be available. This depends on the values the device supports.
When Custom is available and selected for OSD Date and Time the OSD Date And Time X and OSD Date and Time Y control the position of the OSD on the video. The values correspond to the following positions:
OSD values displayed as a graph
PTZ Zoom Step can be used to control how much a camera should zoom when performing a RelativeMove zoom – e.g., single click on the PTZ Overlay Zoom buttons or zooming via the mouse scroll wheel. The default value is 10, i.e., 1/10th of the maximum zoom range of the device. Behaviour between different devices may vary.
A special value of 0 can be set to replace the use of RelativeMove command with a ContinuousMove command. This can be used on devices that have too much movement even on the lowest value of 1.
PTZ send zoom parameter [Always/When changed] – this setting is introduced as a workaround to accommodate some devices that do not handle the ContinuousMove command properly. The setting controls when to include the optional Zoom element in a ContinuousMove command. According to section 5.3.3. ContinuousMove of the ONVIF™ PTZ Service Specification it can be omitted without affecting the current Zoom movement (if any).
When this setting is set to Always, the Zoom parameter will always be included in the ContinuousMove command, even when there is no change in the Zoom movement since the last ContinuousMove command (i.e., repeating the last sent value).
When the setting is set to When changed, the Zoom parameter is only included if a change has occurred in the Zoom movement since the last ContinuousMove command, and omitted if there is no change.
RTP/RTSP/HTTP/TCP Video stream settings
The number of video streams is the number of supported profiles. Each video stream has its own settings section. This gives the opportunity for different video streams to have different setups.
Setting name
Possible values in driver
Value from device
Affected features or Important notes
Media profile (name)
None
Default value: --
The profile name is taken from the device. There is a different video stream representing each of the profiles. Profile 1 is the Video stream 01, the second profile is Video stream 02, etc. If the device supports 5 profiles, there will be 5 available video streams. The max number of Profiles in the driver is 40.
Codec
  • JPEG
  • MPEG4 Simple Profile
  • MPEG4 Advanced Simple Profile
  • H264 Baseline Profile
  • H264 Main Profile
  • H264 Extended Profile
  • H264 High Profile
  • H265 Main Profile
  • H265 Main 10 Profile
Default value: One of the supported codecs
The available codecs can be different per Profile, they are taken dynamically from the device. Some of the values may not be listed in the drop-down menu, if the device does not support it.
Example:
The device has 2 profiles. Profile 1 supports all types of H264 (baseline, main, extended and high) and H265 main codec. The Profile 2 supports JPEG, H264 main and H265 main.
Frames per second
[0.00028, 30.0]
Default value: 8.0
Usually, it is half of the max limit.
The min is always 0.00028. The max limit is taken from the device. It can be different than 30, and for each code or profile.
Keep Alive type
  • Default
  • None
  • RTCP
  • OPTIONS
Default value: Default (Options)
This setting can be used when streaming mode is RTP/UDP, RTP/RTSP/TCP and RTP MULTICAST, otherwise it has no impact on the streaming.
Max. frames between keyframes
[1-1000]
Default value: 1
The max and minimum frames between key frames are taken from the device. For different devices, the range is different.
Max. frames between keyframes mode
  • Default (determined by driver)
  • Custom
Maximum bit rate (kbit/s)
[0,2147483647]
Default value: 10000
Multicast address
none
Default value: The same as the one from the device.
Dynamically taken from the device. If the device does not support multicast setting, multicast settings will not be shown in the product.
Multicast force PIM-SSM
  • Yes
  • No
Default value: No
Source-Specific Multicast (SSM) -identify a set of multicast hosts not only by group address but also by source. A SSM group, called a channel, is identified as (S, G), where S is the source address and G is the group address.
The value is always “No”. Can be changed manually in the product. When value is “Yes”, the driver forces the IP to be part of the SSM group.
Multicast port
[0,65535]
Default value: 0
Multicast time to live
[0,255]
Default value: 5
Quality
[0,100]
Default value: 50
A high value means higher quality. Dynamically taken from the device.
Resolution
All possible values are taken dynamically from device
Default value: 640x480
The resolution is taken dynamically every time from the device. If the device has new resolutions in the next firmware, the device should be replaced/re-added with the same one. The purpose is to regenerate the xml with the new resolution values.
Streaming mode
  • RTP/UDP
  • RTP/RTSP/TCP
  • RTP/RTSP/HTTP/TCP
  • HTTP snapshot or HTTP/TCP snapshot
  • RTP/UDP multicast
  • SRTP/TCP
  • SRTP/UDP
  • SRTP/UDP multicast
Default value:
RTP/UDP
The streaming mode will always have RTP/UDP and RTP/RTSP/HTTP/TCP in the list. If the profile can stream JPEG, in the streaming mode list HTTP snapshot will be included. The other values depend on the device. If the device supports them, they will be in the list.
