Hardware information
The hardware information is placed under the device tab containing basic information for the device. For one device there is only one hardware information as follows:
Setting name | Description | Value taken from device |
Name | Manufacturer name, model name and device IP | ✓ |
Description | -- | × |
Model | Manufacturer name and model name | ✓ |
Version | Firmware version | ✓ |
Serial number | Device serial number | ✓ |
Driver | Loaded device driver:
Address | IP address | ✓ |
MAC address | Device MAC address | ✓ |
Most of the hardware settings are dynamic and depend on device information.
Note
If there is a new firmware uploaded on the device, a procedure of “Replace hardware” or “Remove then add the device in Management Client” is necessary in order to be up to date and working as expected.
Note
Removing a device in Management Client will delete all its saved recordings.
