General device settings
The global settings for the device are settings that should be set once for all channels and streams. They are placed under the device item in “Settings” tab. When global settings change, major functionalities change as well. The following table contains the device’s general settings:
Setting name | Possible values | Value taken from device | Default value |
Model name | Manufacturer name and model name | ✓ | -- |
HTTPS enabled | No Yes | × | No |
HTTPS port | [1,65535] | ✓ | 443 |
HTTPS Validate Certificate | No Yes | × | No |
HTTPS Validate Hostname | No Yes | × | No |
Media Service | Media 1 Media 2 | ✓ | Media 2 service - if device supports it, else Media 1 service. See Media service |
Note
Media Service should be changed only if there are known compatibility issues with the device and the default Media Service
Note
Changing the Media Service requires a Recording Server restart afterward.
Note
When changing Media Service from Media 2 to Media 1, make sure not to have a codec set to H.265. Media 1 does not support H.265, and when using it, some devices incorrectly report the current codec.
