XProtect management server failover (WSFC)
Overview of the upgrade process
LanguageEnglish
When upgrading an XProtect system that uses a management server failover cluster, upgrade the cluster nodes one at a time, starting with inactive nodes and finishing with the active node.
Most of the upgrade can be performed while the system remains operational, but upgrading the final node running the previous XProtect version requires system downtime.
Next: Prepare for the upgrade
