Management server
To make sure clients always connect to the active Management Server, replace the local hostname with the cluster address on each node.
Important
To avoid conflicts, pause the cluster before making changes in Server Configurator
On all cluster nodes:
Right-click the Management Server tray icon and then select Server Configurator.
Go to the Registration page and edit the address (
).Replace the local hostname with the cluster address (role + domain), for example,
https://role.company.com.Click Register.
To verify that the failover works as expected, restart the node owner.
