XProtect Hardening guide
Always use a secure connection by default, particularly over public networks
Versionver27
LanguageEnglish
If you need to access the VMS with XProtect Smart Client over a public or untrusted network, Milestone recommends that you use a secure connection through VPN. This helps ensure that communication between XProtect Smart Client and the VMS server is protected.
Learn more
The following control(s) provide additional guidance:
  • NIST SP 800-53 AC-2 Account Management
  • NIST SP 800-53 AC-17 Remote Access
  • NIST SP 800-53 CM-6 Configuration Settings
